TK IP encryption enable issue in AIR-CT3504-K9
TK IP issue.PNGWLC TK IP Enable issue CLI.PNGI am not be able to enable the TKIP for WPA2 with Wave 2 access points and controller firmware above 8.5.xx
Please find waring message seen.
Warning! WPA2 TKIP cipher is not supported on Wave2 APs for WLAN 2
Please share the all possibility to enable either after downgrade or after upgrade .
Find the attachment for the reference.
Mark Elsen
 - Message is fairly clear , also check this thread for further insights :
                https://community.cisco.com/t5/wireless/is-tkip-available-for-mobility-express-2802/m-p/4259870
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Rasika Nayanajith
You should not enable TKIP with WPA2 as TKIP is broken and you compromise your WLAN security by enabling TKIP with WPA2. Best approach would be phase out WPA/TKIP only supported client over time
Rasika
Thanks all for the time and give the valuable response .
@Rasika Nayanajith  @Mark Elsen
