TLS
ahmedalshami
Level 3
Level 3
hi
i have WLC-WCS-1020 WAP -ACS applaince 4.2 -AD_DC and CA
the Controller was configured
i wanna to deploy TLS
can you help me to explain the right way to migration the AD with ACS and how to configure the TLS certificates.
please advice
owillins
Level 11
Level 11
If you select EAP-TLS, ACS can use it not only to encrypt the initial data sent through the PEAP protocol; but, once a secure tunnel is established between ACS and the NAD, to encrypt (for a second time) the data that is transmitted within the secure tunnel.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/configuration/guide/peap_tls.html
Jagdeep Gambhir
Level 11
Level 11
Pls see the attachement.
~JG
Do rate helpful posts
thanks
i will do this steps and i will back to you
thanks again
