01-28-2019 08:15 PM - edited 07-05-2021 09:45 AM
Hello
I convert from 8.3.111 AP 1815i CAPWAP to moblity express 8.8.100
But i have a problem :
switch layer 2 can ping to Cisco mobility express WLC and my Laptop can pingto Cisco mobility express WLC
but WLC moblity express can't ping the switch ni Laptop and not broadcast SSID and can't get to Web GUI
anyone had this kind of issue with AP 1815i CME?
Urgent , i must to resolve this problem So ,
how i can reslove this CME that allow ME ping to switch and laptop and i can get Web GUI ?????????????
thanks in advance
01-29-2019 08:44 AM
How i can give you full boot console output, ????????, what command used to give output as you like !!!?,,,,,,,,,,
Please patoberli ,
1) ++ I ask you for the first time and last time to access remote by team viewer to help me and it is urgent project, it must be completed this week i need your ok yes or no !!
2) ++ cisco AP1815i Moblity express 8.8.100, I had to explain my problem at the beginning, switch can ping ME but ME can not ping and not broadcast SSID and can't get to Web GUI ..i reset as described previously but it Led red remain Red is blinking ..
so i think try to acces remote via team viwer for first time or help me for problem Led red and convertir to AP CAPWAP normal with privious software 8.3.111
my goal : this AP1815i with 8.8.100 convert to AP CAPWAP normal with privious software 8.3.111 because i used onther AP to be 8.8.111 last version
so i wait you answer and your help definitive
thanks in advance
01-29-2019 08:53 AM
Thanks in advance
Please patoberli ,
thanks in advance
01-29-2019 09:34 AM
i wait you ok for remote access or give me what command used to give full boot console output 1815i Moblity Express as that controller !!!!
that resolve all problem !!!
01-29-2019 11:06 AM
01-29-2019 10:39 AM
show version
does not find as command in controller 1815i !!!
so what command you nedd and i need to acces for remote , please , i need your ok for to morrow !!
02-06-2019 02:43 AM
Configured Country............................... US - United States
1. Country Code configured on the AP is US. The AP has a Regulatory Domain of -I for Tunisia.
2. Why so hell-bent with 8.8.100.0? I wouldn't touch that version for production. Unless there is critical requirement, go with 8.5.140.0
01-29-2019 06:26 AM
How i can correct Led red for cisco ME 1815i ????????,
please , this project wireless urgent
please help me for this probem !!!
01-29-2019 06:09 AM
cisco 1815i Cisco Moblity EXPRESS IS now Led id Red now after reset this AP 1815i ????????, as you tell me
Cisco Controller) >show tech-support
---------------Show boot---------------
Primary Boot Image............................... 8.8.100.0 (default) (active)
Backup Boot Image................................ 8.8.111.0
But i would this Mobilty 8.8.100 convertir to AP CAPWAP 8.3.111 as default previous :: my Goal ?,,,
so how i can do after i used reset and now the 1815i is led red !!!!!
why now this 1815i ME is led RED and not other coloer ??????????
01-29-2019 06:10 AM
01-29-2019 06:11 AM
why now this 1815i ME is red Led ??????????,
01-29-2019 05:49 AM
now ciso 1815i Mobility Express led is red after i do reset as you tell me !!!
But i would this 8.8.100 convertir to 8.3.111 as default . so how i can do that ??????? convertir to AP capwap as I bought
Problem , now led is red not green but configuration remain ????????!!!!
01-29-2019 05:08 AM
you can acces for remote access for this AP 1815i Moblity expres with Team viewer ???????,
i need your answer Yes or No to accpet remote acces
i give you ID .. please help me for this 1815i 8.8.100 that allow me convertir to AP CAPWAPA ...
i would convertir to AP normal as first
because the config is remain and not delete ???,,
01-29-2019 05:09 AM
01-29-2019 04:42 AM
Enter User Name (or 'Recover-Config' this one-time only to reset configuration to factory defaults )
what i put ???????,,
01-29-2019 04:45 AM
i put " Recover-Config " or name user ??????,, allow upgard to 8.8.111
please you can answer me !! i wait for your answer to help !!
thanks in advance
