01-28-2019 08:15 PM - edited 07-05-2021 09:45 AM
Hello
I convert from 8.3.111 AP 1815i CAPWAP to moblity express 8.8.100
But i have a problem :
switch layer 2 can ping to Cisco mobility express WLC and my Laptop can pingto Cisco mobility express WLC
but WLC moblity express can't ping the switch ni Laptop and not broadcast SSID and can't get to Web GUI
anyone had this kind of issue with AP 1815i CME?
Urgent , i must to resolve this problem So ,
how i can reslove this CME that allow ME ping to switch and laptop and i can get Web GUI ?????????????
thanks in advance
01-30-2019 09:40 AM
01-30-2019 09:58 AM
I wait you help please : for two problem !!
01-30-2019 10:37 AM
Patience please, this forum is only my hobby.
Thanks for the logfile. It shows that this AP is NOT ready for Mobility Express. This means the wrong model was ordered/bought. There are two models you can buy, one which comes with Mobility Express image and one which comes with CAPWAP Image for Wireless Controllers.
It looks like you bought K9 instead of K9C. This is the reason why you have so many troubles getting them to work.
So first thing you have to do now, finish configuring your 8.8.x ME model. Once that one works correct, you have to convert the other APs to a ME image.
Try this manual here: https://community.spiceworks.com/how_to/149424-how-to-convert-upgrade-a-cisco-aironet-1815i-from-capwap-controller-based-to-mobility-express-standalone
Important, replace the image in step 7 with the file AIR-AP1815-K9-ME-8-8-100-0.tar. It must be this file!
After that the AP should join your Master AP and will be automatically configured from your master.
01-30-2019 10:50 AM
you say " you have to convert the other APs to a ME image. " WHY ????????, NO ==> i would to say that other AP that running 8.3.111 ( 29 AP new ) can connected and can communcateand join with ME 8.8.100 :=====> that is my Goal
so How i can do that ??????, configuration switch or version or what command that i can used in AP or ME ???????
what are the methods ????????,i wish that you undersant me my question
i than you a lot for all message
thanks in advance
01-30-2019 11:09 AM
01-30-2019 08:12 PM
i convert the 29 AP to 8.8.100 that allow AP join to ME ??????
===> because ME ( is only as conroller ) and other AP remain AP !! ( this my goal ) . why AP convertir to 8.8.100 . if i convert to 8.8.111 is better ??????,,
2) seconde problem , you don't answer me. password is same as e the Setup Wizard from CLI !!! why when i put password , is refused ???,,,
there are two point !!!
01-30-2019 08:32 PM
you means replace the image in step 7 only ( 8.8.100 ) . that allow AP join to ME ???????????,
that's what you mean ???????,,
other think , if i enabled DHCP in ME or not ?,,,,,,,,,,,,
thanks in advance
01-30-2019 11:57 PM
