Trouble setting Cisco 3702i to autonomous
Andrew White
Level 2
Level 2
I only did this a few weeks ago and it was easier, but today I can't reset another spare AP and set it to autonomous.  I was originally connected to our WLC so I've consoled in and removed the config.txt and the private-multiple-fs anre rebooted:
But my command to add the correct firewall doesn't work am I in the wrong mode?
archive download-sw /overwrite /reload tftp://192.168.1.23/ap3g2-k9w7-tar.153-3.JI5.tar
The archive download-sw command isn't even available.
Other Wireless - Mobility Subjects, Aironet Access Points
Any ideas?
Rasika Nayanajith
Hi Andrew,
Try "debug capwap console cli" command first & then do archive download command.
Refer below
https://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Rasika
*** Pls rate all useful responses ***
