03-12-2007 01:54 PM - edited 07-03-2021 01:46 PM
Hello all, I am having trouble configuring a 1410 bridge to accept clients. I am running SW 12.3(7)JA3. I set the bridge to Root mode and assign basic settings but cannot connect with a client. I can see the SSID broadcasting. Any ideas?
03-16-2007 11:53 AM
Check if client sees the SSID of the bridge.If not adjust the channel number on the bridge. If SSID is broadcast check for the authentication type.Is it configured same on the bridge and the clients.Refer URL for configuring the bridge
03-16-2007 11:58 AM
Unfortunately, I have been informed by Cisco that the 1410 will NOT accept any clients. It only uses the UNII 3 band and is not capable of taking clients. Explains why I could see the broadcasted SSID, but not connect. Thanks for the reply.
