Bookmark
Subscribe
2196
Turning off Wifi Help Please
deantherhino1
I like to turn my wifi off when I am not using it. I have been using this website to turn it off and on the past few months (http://192.168.0.1/Docsis_system.asp). Recently it has shut down and I havent been able to find another website or link. If anyone could help that would be great.
Leo Laohoo
The IP Address of "192.168.0.1" is a private IP address.  So this means that the IP address you're browsing to is internal to your network.
abwahid
Level 4
Level 4
Check your current IPv4 Default Gateway IP address in your LAN adapter detail, then type that IP address at your browser address bar and hit Enter.. it will open webpage of your installed Access-point , there you can turn on your WiFi.
