Two Aironet APs
cmd1
I have two Aironet 350 APs installed in our Enterprise wharehouse. I keep getting the error message "Network Bridge Loop: Received packet from Self destined to [AWC Mcast All]014096ffffff on port "fec0" on both AP. Is there some extra config that must be done when installing two APs when their signals overlap.
fjuch
Are they on different frequencies. They should be. The clients will roam to the best AP
Thanks for the tip. Where do you set the frequency?
When the signals overlap, the AP's should be on different frequencies and have the same SSID. That eliminates interference in the overlap zone. In the US, stick to channels 1, 6 & 11.
Set the frequency in the AP Radio/Hardware page.
Thank you very much! They were both set to channel 6.
Thanks again!
