ā10-09-2019 09:14 PM - edited ā07-05-2021 11:07 AM
I have a ubiquiti nano hd wireless router which works great, and I would like to be able to configure it with my cisco 2921 router and cisco 3570 poe switch to use for my guest wifi and other wireless appliances.
Solved! Go to Solution.
ā10-10-2019 11:53 PM
ā10-10-2019 02:33 AM
ā10-10-2019 12:00 PM
ok to be sure,
I will create 2 vlans or 2 virtual interfaces on the router? or switch?
vlan 55 for appliances
vlan 60 for guest
Create an ACL on the router for the guest wlan & vlan blocking access to the appliances vlan?
Since my wireless is being powered via poe on my 3750 switch, does anything have to be configured on it?
does anything need to be corrected on the ubiquiti hd router?
ā11-09-2019 09:54 PM
not working? I just want to know can I plug the ubiquiti into my switch, and then do I really need to create 2 vlans? I am only using a wireless ap not trunking with another appliance thru the switch. I have created 1 vlan on the switch and an acl on my cisco 2921 router to allow.
ā11-11-2019 08:48 AM
