Bookmark
Subscribe
2457
Unable to browse - Wireless access point
JOACKIM12
I have set up my access point (Cisco Aironet 1200) by assigning IP address, SM, DG, DNS. I have also setup my Wireless Client LAN adapater card with its own IP Address, SM (Same as access point),DG (Same as access point), DNS (Same as access point). I am getting the connection signal on my Laptop but I can not browse. I checked on the ADU utility (Installed on Laptop)and all the tests are OK (Meaning all the connections are OK). When I check on the management tool for the access point (Using my browse) I found this error message: Interface Dot11Radio0, Deauthenticating Station 0040.96ad.3676 Reason: Disassociated because sending station is leaving (or has left) BSS
Please help. How can I resolve this problem
22 Replies 22
George Stefanick
Are you using any security wep wpa?
Yes I am using the WEP encryption (Mandatory).
dfiling
I have seen this error when I had a Netgear client adapter the two do not get along. So if you do not have a client adapter that is Cisco based like Linksys etc, then that could be why. The only way to fix was to boot the AP and then it would just run through that same error five to ten minutes later.
The adapter I am using is the Cisco Aironet 802.11a/b/g WIRELESS ADAPTER. Could it also be a problem of some interference ?
can you ping the AP?
No I can not ping the AP
I'm sorry I should have been more clear-
Did you try to ping it from the wired side?
If you cannot ping from the wired side, you haven't even made it to the radio yet to have interference.
Once you have tracked down this issue and are able to ping from the wired side, then see if you associate (layer 2) and authenticate (layer 3).
let us know how far you get
I am able to ping from the wired side. Can you please advise the instructions on how to associate (layer 2) and authenticate (layer 3)
Where do I check for associate (layer 2) and authenticate (layer 3) ?
Sorry man,
association to the AP occurs at layer 2 of the OSI. This is the ssid. The ssid on the radio and the client card need to match. Then authentication ( wep, wpa-psk, whatever)occurs at layer 3.
First I would remove all security from both and set it up default to see if you can connect with just an ssid and no security.
basically you start over from zero and build it back up until it either breaks again or you are successful.
I removed all the security from both. I still cant browse. The Link quality is showing as Excellent and the connection status shows the SSID, Access point name and the Access Point IP Address. The current Receive/Transmit Rate 54.o Mbps
Ok this is kind of thin but here goes...
Can you browse from the Wired side? If not console in and look for 'no http server' or something like that towards the end of the config. This effectively shuts down http and wont let you browse.
basically type the command in without the 'no' and save it and then see what happens
no ip http server...
The fix is :
config t
ip http server
end
copy run start
I'm pretty sure that's it...
No I can not browse on the wired side
Please confirm that I do the following:
1. Connect the AP to Laptop (Console port)
2. Connect using HyperTerminal
3. Type on Command prompt:
config t
ip http server
end
copy run start
