Unable to browse - Wireless access point
JOACKIM12
I have set up my access point (Cisco Aironet 1200) by assigning IP address, SM, DG, DNS. I have also setup my Wireless Client LAN adapater card with its own IP Address, SM (Same as access point),DG (Same as access point), DNS (Same as access point). I am getting the connection signal on my Laptop but I can not browse. I checked on the ADU utility (Installed on Laptop)and all the tests are OK (Meaning all the connections are OK). When I check on the management tool for the access point (Using my browse) I found this error message: Interface Dot11Radio0, Deauthenticating Station 0040.96ad.3676 Reason: Disassociated because sending station is leaving (or has left) BSS
Please help. How can I resolve this problem
22 Replies 22
actually first type in
show run
and then see if you find
no ip http server
down towards the end of the config...
if it is there then by all means proceed.
I can not execute the command SHOW RUN. The only parameters for the SHOW command are:
aaa Show AAA val
auto Show Automation Template
call Show call
caller Display information about dialup connections
cca CCA information
class-map Show QoS Class Map
clock Display the system clock
controllers Interface controller status
crypto Encryption module
dampening Display dampening information
dot11 IEEE 802.11 show information
event-manager Event manager information
exception exception information
flash: display information about flash: file system
hardware Hardware specific information
history Display the session command history
hosts IP domain-name, lookup style, nameservers, and host table
iapp DDP IAPP
inventory Show the physical inventory
ip IP information
led LED functions
location Display the system location
login Display Secure Login Configurations and State
memory Memory statistics
policy-map Show QoS Policy Map
radius Shows radius information
sessions Information about Telnet connections
snmp snmp statistics
ssh Status of SSH server connections
ssl Show SSL command
table-map Show Table Map
tacacs Shows tacacs+ server statistics
template Template information
terminal Display terminal configuration parameters
time-range Time range
users Display information about terminal lines
version System hardware and software status
Please advise
This is an IOS autonomous AP, right? If it is LWAPP that's a problem...please list the version of code.
-show version-
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(7)JA2, RELEASE S
OFTWARE (fc1)
You can get to a config prompt (config #)and change the config, but you can't see the config.
Hmmm. Sounds like your boned until you can get the config.
Or you can type the command in anyway and see what happens...don't forget to save it if you do
I executed the command: copy run start and I am now prompted for:
Destination filename [startup-config]?
What should I type ?
just keep hitting enter
Thanks. I managed to browse the internet from the Laptop
