Unknown Device connected to router
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-13-2024 09:08 AM
I have been trying to figure out which Cisco device hardware is Model Gen8. I cannot distinguish if this is anything I own. I reset my router but some how the Cisco HW keeps connecting to the router. From the wifi analyzer I see it also supports the following services: Layer3Forwarding, WanCommonInterfaceConfig, WanIPConnection, WFALanConfig. Tried to find actual HW searching online but nothing shows specific to that model name. I am trying to understand if this is one of Cisco server catalyst that I had read online. Hoping I am not being hacked. If anyone is familiar, please help to confirm.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-13-2024 09:22 AM
- The term Gen8 is used for categorizing different models of HP ProLiant servers ,
M.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-15-2024 03:41 AM
@jax081 You haven't said what model of router this is but if it runs IOS or IOS-XE then you could enable CDP and LLDP and use "show cdp neigh detail" and "show lldp neigh detail" which might show you more detail if the device supports CDP or LLDP.
Please click Helpful if this post helped you and Select as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's and TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's, Best Practices for 9800 WLC's and Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
