upgrade 2802 controller
owen2
Level 4
Level 4
Hi All,
I have a customer who is expanding his WIFI coverage with a new AP.
we reliase the new AP is running on a newer firmware 8.10, while the controller is on 8.5 and another 2 AP.
We managed to get hold of the latest firmware. 8.10.151
which are files are used for the upgrade?
9 Replies 9
Leo Laohoo
What WLC is used?
AP 2802 work as WLC and AP
HI,
im only able to use HTTP for upload.
TFTP server is not installed.
Its fail after 99%
is it a bug ?
May be try different browser or try setup TFTP :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_0110.html
BB
@owen2 wrote:
Its fail after 99%
What is the exact error message?
its state transfer fail.
i tried using the whole zip file and just ap3g3 file.
what browser you using post the error message screenshot ?
BB
I want to see the exact error message.
If you are unable to provide the exact error message, raise a TAC Case.
