upoe and radio
bluesea2010
Level 5
Level 5
As i understand from the below table the 8x8 radio will function even with poe+ , why third row show  upoe
what is the purpose of upoe here then ?
13 Replies 13
balaji.bandi
As per my understanding PoE+ delivery maximum 30W, UPoE (PoE++) Delivery 60W.
BB
My question for 8:8x8 radio  ap require more  than 30 watts , as per the table it  does not require
That was m confusion
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/nb-06-cat-9130-ser-ap-ds-cte-en.html
if you do not use USB, it will not required more, but POE++ (UPOE) can be used for other devices in the network, where they required to connect like any PoD/CCTV/small compute system/ PoS
BB
Leo Laohoo
Just turn off USB.
bluesea2010
Level 5
Level 5
What is that USB for ?. it means the  8:8x8 radios works with poe + ?
Charge your smartphone -- I am serious.
Hi @Leo Laohoo
I know this for zigbee and ble connection , but the cisco  9130 has integrated zigbee and ble . that was my question
second is it true  thing poe + is giving power between  20 wats and 30 wats
for 8:8x8 radios require 25 wats, is it possible  AP will draw always above 25 wats  or any possibilities it will go below 25 wats ?
Zigbee is software disabled in the AP because there is "no demand" to get them enabled.
Biggest users of Zigbee are hotels.  Upgrading APs is not a priority -- Trying to "stay afloat" is.
Remember:  If it ain't broke, don't fix it.
Can you  comment on the below
We have several 9130 in our network.  If I disable USB, the AP will draw up to 30.0wac and the WLC is reporting them as "full power".
Hi @Arshad Safrulla
Even without  upoe catalyst 9130axi can turn all 8x8 radios ?
Yes it can, it's clearly mentioned in the same screenshot you shared.
PoE power consumption
2.4-GHz radio
5-GHz radio
Link speed
USB
LLDP
802.3at (PoE+)
4x4
8x8
5G
N
25.5W
