UPOE power for the new AP3800 access points
gp1200x
Level 2
Level 2
If I do not have a 3850 to provide UPOE power are there any UPOE injectors currently available that are known to work with the AP3800s?  I  know 802.3at  injectors will work but these need more power to fully utilize them properly.  I have purchased the external 50W power packs for them but a UPOE compatible injector would be a nicer solution.
Leo Laohoo
Input power requirements
  802.3at PoE+, Cisco Universal Power over Ethernet (Cisco UPOE®)
  802.3at power injector (AIR-PWRINJ6=)
  50W power supply (AIR-PWR-50=)
Leo Laohoo
after a lot of work I found no one that makes a compatible Cisco UPOE power injector as of this time. Thanks
I have a 3802E and I have no issues powering it via POE+.
Cisco has this power injector which is fully supported (which was already posted by Leo): AIR-PWRINJ6
