USB WLAN card compatitible with Vista
pppyyyppp
Can anyone advise which model/brand of USB WLAN card is compatible with Vista. Our company run MS-PEAP with WEP-128 bits encryption?
Does not found in the CCX program as it only reflect Windows XP and 2000, there are no Vista.
dennischolmes
Level 7
Level 7
Vista is not officially supported by Cisco yet so you won't see any CCX info on it yet. As for a USB adapter I would shop the local retail outlets. I've been told d-link has one.
