USC3331 signal booster fault
RobertWood55794
my signal booster has a continuous fast flashing green light which i gather means that it is in th "configuration cycle" but never seems to stop.. ive pressed the reset button several times and even tried holding it in for 10,20,30 seconds over the last 36 hours but after the initial red light, the green starts to flash again..
marce1000
          - Check the adapter and or try with another one.
 M.
Do you mean the cable..? I don’t have an adaptor just a Router and the Cisco USC3331
             - Ok. check the cable too.
 M.
