Using different interface as management interface in c9800
Leftz
Level 9
Level 9
Hi C9800 wlc is setup. The interface Tw0/0/1 is configured as management interface. ssh and gui can access the wlc. but we reconfigured the WLC from scratch using Te0/1/0 as management interface, GUI cannot access wlc again. Is this because we are using different interface? Thank you
9 Replies 9
 I dont think so.  Does this interface Te0/1/0 is Layer 3 interface or it is part of a Layer 3 port-channel or it is member of some vlan with Layer 3?
 You should be able to manange the WLC from some IP address.
Leftz
Level 9
Level 9
Thank you very much for your reply. We are using two ports Te0/1/0 and Te/0/1/1 as trunk and channel. and using vlan as management interface.
Can you share the sh run ?
Or at least "show ip int br"
show run int port-channel X
show run int Te0/1/0 and Te/0/1/1
balaji.bandi
check this video nice one :
https://www.youtube.com/watch?v=UhZedbZ1pIA
I have installation guide in my archive post later (not in hand)
BB
An overview of the 9800-L controller, Showing the physical ports, how to setup and configure the box. View Alert Command show facility-alarm status Video Created using: Logitech Camera - https://amzn.to/2OvquKG Blue Yeti Microphone - https://amzn.to/33hK29H OBS Recording - https://obsproject.com/
Leftz
Level 9
Level 9
Please see below:
WLC#sh ip int bri
Tw0/0/0 unassigned YES unset down down
Tw0/0/1 unassigned YES unset down down
Tw0/0/2 unassigned YES unset down down
Tw0/0/3 unassigned YES unset down down
Te0/1/0 unassigned YES unset up up
Te0/1/1 unassigned YES unset up up
GigabitEthernet0 unassigned YES NVRAM administratively down down
Port-channel10 unassigned YES unset up up
Vlan1 unassigned YES NVRAM administratively down down
Vlan10 10.10.10.89 YES NVRAM up up
WLC#sh run int port-channel 10
interface Port-channel10
switchport mode trunk
WLC#sh run int te0/1/0
interface TenGigabitEthernet0/1/0
no negotiation auto
channel-group 10 mode active
WLC# sh run int te0/1/1
interface TenGigabitEthernet0/1/1
negotiation auto
end
You should be able to manage the WLC using the IP 10.10.10.89.
If you are not, you need to check the device where the WLC is connected.
I have used mamangent gig0/0 and it works as expected. can you post full config
here is my Cat 9800 config : (simple steps works and in production now)
https://www.balajibandi.com/?p=1595
BB
Leftz
Level 9
Level 9
Yes its ssh, but not GUI
I checked and get to know many users have this issue. Please see the link.
https://community.cisco.com/t5/wireless/cisco-wireless-lan-controller-9800-l-c-unable-to-login-to-gui/td-p/4025477
Arshad Safrulla
In all 9800 physical appliances you have a dedicated management port (service port). It is highly recommended that you configure this port for management access;
interface GigabitEthernet0
description :d= Management_Switch_GE1/0/10
vrf forwarding Mgmt-intf
ip address 10.0.0.101 255.255.255.0
negotiation auto
no cdp enable
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 10.0.0.1
If you require in-band management to WLC then you can configure a SVI, For example
interface Vlan101
description AP-Management
ip address 10.1.0.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.1.0.1 (Default route is mandatory)
Also in order to have http/s access to the WLC you need to use below commands;
ip http server (you can disable this if required)
ip http secure-server
ip http authentication local
Configuring any new L3 ports in the WLC is perfectly possible, but must be avoided and not recommended due to complexities it brings. Cisco recommends using VLAN Interfaces (SVI's) in the WLC instead of configuring L3 interfaces. Also if you are not using mdns or dhcp relay only 1 SVI in WLC is more than sufficient. Always read the 9800 best practices guide if you need more info.
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html
