Using WDS for Rogue AP detection
mnlatif
Level 7
Level 7
We are using Cisco 1200 series IOS based access points. On the client side we have a mix of Cisco,Intel,etc wireless cards. PEAP is being used for authentication and TKIP as encryption.
In this scenario
1. Can we use WDS for rogue AP detection ?
2. Can WDS be used for some other advantage under this scenario ?
Naman
minie
Level 7
Level 7
Yes, sure you can use WDS. Detecting rogue AP is one of functions of WDS. WDS consists of only IOS APs, no clients are involved.
dmfong
Community Member
Trivial question: How do you setup a 1200 to use WDS for rogue AP detection? I have WDS enabled, but it's not reporting any of the AP's I have running.
