View the connected data rate of a Mesh backhaul link
cmcclinton
Level 4
Level 4
Is there anyway to see what the actual operating data rate/MCS/streams are for a connected Mesh AP?
Seems like something that would be useful to know before doing testing but I cant seem to find that information via 9800 CLI or GUI.
The show mesh backhaul command for an AP seems like a good place to start but all the bhrate shows is the configured value of auto, but what rate is being used?
show ap name AP-MAP mesh bhrate
show ap name AP-MAP mesh backhaul
Doing a linktest and looking at the results seems like the next obvious option but you have to manually select a data rate or MCS number and even then the result don't show details of actual data rate and spatial streams used.
Surely each MAP that is connected to a RAP has connected at its best data rate just like any WiFi client, why can't this be seen?
marce1000
 - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-3/config-guide/b_wl_17_3_cg/m_mesh_ewlc.html
Using a Link Test on Mesh Backhaul
Use the following show command to verify the use of link test on mesh backhaul configuration:
Device# show ap name 1542-RAP mesh linktest data 7070.8bbc.d3ef
380e.4d85.5e60 ==> 7070.8bbc.d3ef
                      - Change command parameters accordingly ,
                 Also have a look at the  show wireless profile mesh ....
   commands in the document.
 M.
