Virtual Wireless LAN Controller
Farandinio
Community Member
Hello, I'm looking to get a trial of the virtual wireless LAN controller.
I picked up a Airnet pretty cheap though ebay and thought that I could just download the wireless controller, but as I don't have anything listed in my account I can't.
Is there a trial I can get / full olver version of the software?
Tried to get my hands on a meraki, but also didn't go down so good as I'm not a business. I'm just trying to build out my home lab with setups I see so I can learn to support them, but also learn and get more familuar with cisco and start to undertake some training.
Any help /  Advise you can give would be great. The Cisco support team via twitter pointed me here, not too sure if this is the right place, but I'm sure you can advise / point me in the right direction if not.
Thanks!!
balaji.bandi
if you are lucky enough google have many results and  people uploaded.(i can not provide the link to download - excuse me here)
if not contact local your SE or cisco partner can able to download for you with trail license to test.
May be you have cheaper AP you have purchased make sure it compatable with right control software you download for your test.
good luck.
BB
omz
If the AP is supported by vWLC you can Google for the .ova file for vWLC.
Have a look here if AP is supported - https://www.cisco.com/c/en/us/support/wireless/virtual-wireless-controller/products-release-notes-list.html
If not supported by vWLC, you can install a standalone software to learn and play.
For Meraki you can have play with the read-only always on sandbox. https://devnetsandbox.cisco.com/
https://meraki.cisco.com/
Hope this helps.
patoberli
Check if you can get your hands on a cheap WLC 2504 with at least 5 licenses. Also make sure that your AP is supported by the 2504. It might require a software upgrade/downgrade.
