Virtual WLC ssid broadcast for some users
Youssef Aoufi
Level 3
Level 3
Hi there ,
I just set up a virtual WLC and configured Aps with 3 SSID.
I configured APs in flexconnect mode, since with local mode , i couldn't see my SSIDs broadcast.
Now most of users , aprox 90% are connected, but 10% cannot see the SSIDs . It's not a coverage issue, because we tested many devices in the same room of the affected users and we can see this SSIDs.
Any idea
Thanks in advance
2 Accepted Solutions
Sandeep Choudhary
Please check if any AP Groups except default group created on WLC!!!
Don't forget to rate helpful posts
Please also check the data rates allowed in both band!!!
Reagrds
Sandeep Choudhary
Hello Sandeep,
Thank you for your help.
I have not configured any new AP Group. I have only the default.
Reagrds
Thanks Sandeep,
You saved me.
It was a data rate issue.
