Wireless setup
amh4y0001
Level 5
Level 5
debug capwap console cli
debug capwap client no-reload
archive download-sw /overwrite tftp://10.0.0.2/ap3g2-k9w7-tar.153-3.JC
more flash:/env_vars | include BOOT
** it didnot helped and following message appears repeatidly:
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
***** can some advise what may be possible reason, or need to correct configuration? (I do not have WLC and want to use AP as standalone).
Sandeep Choudhary
please go through these posts:
https://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
https://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Dont forget to rate helpful posts
6 Replies 6
Sandeep Choudhary
Thanks for reply,
The first link says the following:
But is it BVI interface instead of Fa 0 ?
 AP588d.0903.e31c (confg)# int fa 0
It must be fa0 or gig0 interface
Please follow the procedure as per my last post.
Dot forget to rate helpful posts and please mark this question answered, it may help others.
Checked it again and all the time i receive the following message:
*** I have following Interfaces:
BVI1                       10.10.10.102    YES TFTP   up                             up
GigabitEthernet0           unassigned      YES manual up                    up
GigabitEthernet1           unassigned      NO  unset  administratively  down
Checked with both BVI and G0, in either interface I can not access TFTP or Ping is not successful.
Still your AP is working with Controller based image.
First convert it to Autonomous mode then start with conifg.
Don't forget to rate helpful posts
Sandeep you solved it, the articles you referred helped me to convert from LWAP to AP., thanks.
Will continue to configure it.
