Virtual WLC/Wireless Lan Controller supported AP's
benbollinger
Level 5
Level 5
What Ap's are supported with this new vmware option?   I have some 1131's and 1142's, but the document says all 802.11N ap's are supported.  Does that mean the non-N ap's are not?
wjenkins
Level 3
Level 3
Here is a link to the data sheet on the vWLC.
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps12723/data_sheet_c78-714543.html
The 1130 and 1240 APs are supported per the data sheet.
benbollinger
Level 5
Level 5
I saw they were supported but wasn't sure if you needed the N versions. Any idea?
The 1130 and 1240 only support 802.11b/g and 802.11a and will never support 802.11n.
The APs are supported on the vWLC but obviously will not have the same functionality as the newer model 802.11n APs.
