Vlan Interface IP
Michael Grevald
Community Member
Philip D'Ath
Meraki Community All-Star
It needs to be a unique IP address.  The "gateway" would typically point to your core switch VLAN IP address.
7 Replies 7
Philip D'Ath
Thanks philip!
So basically, if I have 2 controllers & 2 different VLAN interfaces, then I would need to assign a total of 4 unique ip addresses, that is, assigned per interface per controller, is that correct?
Are you sure about this? Because we do have a running wireless production environment with multiple wlans and 4 controllers. However, the gateway for these existing "working" vlans/wlans are NOT set to the IP address of that specific vlan, instead they are set to the 'gateway of that vlan subnet'. And things have been working great. I am only trying to fix some misconfigured IPs for couple of newly added interfaces on the WLC.
Philip D'Ath
Correct.
Well, if you don't configure the gateway and the controller needs to forward a packet itself using that interface then it will fail.  I guess you just don't have anything enable that requires the controller to do this so you are getting away with it.
Yes, we do have the gateway configured on the 'Inteface' on the WLC. What I meant was its just not set to the IP address of that VLAN, instead set to the gateway of that VLAN subnet.
So, lets say the subnet range for my working WLAN/VLAN is 172.16.192.0 /21. So the IP address for that subnet is 172.16.192.2 on the core and the gateway for this subnet is 172.16.192.1. And this is also the gateway set for that interface on the WLC as well.
Philip D'Ath
That sounds correct.  You get the jist.  The "gateway" should be configured to be whatever the correct gateway is for that VLAN.
Great! That clears the confusion. Because the whole thing was configured by a company few years back, so just needed to make sure before I proceed.
Thanks philip for your help!
Philip D'Ath
You're welcome.  It would be great if you could rate and mark helpful answers.
