VLAN on SSID
trinh-nguyenthimai
Frequent Visitor
Frequent Visitor
I would like to know we can assign 2 or 3 VLANs on same SSID or not? If can what should I notice in configure AP?
jagan.chowdam
Yes, you can map multiple VLANs to single SSID.
In IOS-XE this feature is called "VLAN Groups". Refer the link below for more info:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-9/config-guide/b_wl_17_9_cg/m_conf_vlan_grp_vewlc.html
Make sure to review the pre-requisites and limitations from this document.
In AirOS controllers this is called "Interface Groups"
Ref: https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/ports_and_interfaces.html#interface-groups
Jagan Chowdam
/**Pls rate useful responses**/
eglinsky2012
What is the purpose of the multiple VLANs? Are you looking to balance clients across the VLANs, or are you looking to assign VLANs to devices or users based on certain criteria?
We would like to balance clients across the VLANs for simple at users' side.
Simon Blomqvist
Level 3
Level 3
On an AireOS a WLAN can be assigned an interface group with several interfaces and on a 9800 a WLAN you can assign a VLAN group with several VLANs. An algorithm then places the client based on its MAC address on a VLAN in the VLAN group. This only works with central switching.
Another option is to return a VLAN from your AAA server during authentications, then different clients could use different VLANs based on their authotization.
