vs mcs
wyfy-2015
Level 3
Level 3
What is the difference between  ofdm rate  vs mcs rate ?
7 Replies 7
Rasika Nayanajith
OFDM is the modulation technique used in 802.11a ,802.11g ,802.11n or 802.11ac. If you need good understanding about OFDM refer below
https://www.cwnp.com/understanding-ofdm-part-1
https://www.cwnp.com/understanding-ofdm-part-2
https://www.cwnp.com/understanding-ofdm-part-3
https://www.cwnp.com/understanding-ofdm-part-4
If you talk about OFDM rate, I think you refer to the data rates 6,9,12,18,24,36,48,54 Mbps values.
MCS rates are used in 802.11n & 802.11ac. Refer below for those values
http://mcsindex.com/
Below page also gives what RSSI & SNR you should have to achieve these MCS rates.
http://www.revolutionwifi.net/revolutionwifi/2014/09/wi-fi-snr-to-mcs-data-rate-mapping.html
Rasika
*** Pls rate all useful responses ***
what is the  relation between theses datarate and mcs inidex .
How would you read the mcsindex ?
Refer below to see what data rates relate to each MCS index value.
Rasika
If i am getting a data rate (n device )  like "6,9,12,18,24,36,48,54" Means i am not  getting  802.11n data rate  ?
Yes, you are not.
to get 802.11n data rates below need to fulfil
1. SSID should have either no security (open) or WPA2 with AES encryption (either PSK or 802.1X)
2. WMM should be enabled (either Allowed or Required under WLAN QoS tab)
Rasika
What is the difference between the  data rate which is shown in the beacon fram  and  the data rate  which is shown in the encrypted data frame
Ack Frame
Encrypted Data Frame
Management Frames are sent lowest mandatory rates configured. In your set up 12Mbps might configure as mandatory.
Data frames can be sent any supported data rates (including MCS). According to the value 13Mbps, it is MCS1 with 20MHz channel width setting.
Rasika
