Showing results forĀ
Search instead forĀ
Did you mean:Ā
VTP over wireless bridge
salamislimy
Frequent Visitor
Frequent Visitor
HI
We have switches connected over a wireless bridge, however VTP information is not sent across correctly.
I have seen old community posts with older models, wondering if there is any official Cisco document suggesting that VTP will or will not work across a wireless bridge.
Setup
9300 L switch running VTP mode client ,VTP version 3 , is connected over wireless bridge consisting of C9124AXD-Z APs ( 9800 controller) to C3560CX-8PC-S switch also running VTP mode client
9300 L switch
#show vtp status
VTP Version capable : 1 to 3
VTP version running : 3
VTP Pruning Mode : Disabled (Operationally Disabled)
VTP Traps Generation : Disabled
Feature VLAN:
VTP Operating Mode : Client
Number of existing VLANs : 30
Number of existing extended VLANs : 0
Maximum VLANs supported locally : 4096
Configuration Revision : 1
C3560CX
#show vtp status
Feature VLAN:
Number of existing VLANs : 18
Maximum VLANs supported locally : 1005
Configuration Revision : 0
Primary ID : 0000.0000.0000
11 Replies 11
@salamislimy
Why both switch are client?
Switches in VTP client mode receive VLAN information from VTP servers and synchronize their VLAN database accordingly. However, they cannot create, modify, or delete VLANs
VTP server is the core switch, hope this diagram helps
the VTP use native VLAN in trunk link ONLY
I think the wireless bridge is not trunk
MHM
There is a bug, I bit old this is true, but it says that when the VTP is over bridge is must use Vlan 1 as native.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCeg12593
As you are using a 3560 in one of the sides, this could apply
I did see this, but it said it was fixed in a later version, so expected that this will be fixed by now
But, do you have at least one vlan in native state for this trunk? Even though cisco remove the limitation for vlan1, I believe you must have some vlan in native state in both sides
yes we do have a native vlan on both ends
I would recommend you to capture the traffic send towards the bridge with wireshark so that you can check to see if the VTP is even being sent to the air.
 you can use port span on the 9300 or 3560 and you can easily see this.
srimal99
Level 5
Level 5
Have you enable vlan over the links or are those in  trunk mode ?
Hi @srimal99
Its all trunk
As @Flavio Miranda mentioned you can do packet capture on Wireshark to see traffic reaching Cisco 3560. I had similar issues where bridge connecting  port goes in to error disable state in the switch . Enabled "spanning-tree BPDU filter enable" in the port level and issue resolved.
