vWLC | Error in setting management interface IP
khaledtawfik192
Frequent Visitor
Frequent Visitor
Greetings,
I'm working on setting up an EVE-NG lab and I have 2 different ISO images for versions 8.3.141 and 8.7.102, when I'm doing the initial setup of the 5500 vWLC after I configure the management IP I get the error message saying Error in setting management interface IP on both versions of vWLC.
I have seen recommendations online to make sure service port has a non-routable IP address, which I have. I tried 1.1.1.1 and 2.2.2.2 for the service port.
Service Port and your Management in different Subnets, which I have.
I can't do any show commands because I'm in the initial setup.
My flow control is set to none on serial. I rebooted the controllers multiple times and still getting the same issue.
Any idea what could be wrong here?
Thank you in advance for your help.
5 Replies 5
Rich R
8.7 was deferred and is end of support.
8.3.141 is end of support and isn't even the latest release of 8.3
So start off by getting an up to date version of the code (always refer to TAC recommended link below) - currently:
https://software.cisco.com/download/home/284464214/type/280926587/release/8.10.190.0
But your problem sounds more fundamental than that.
- is that the exact error that you're seeing "Error in setting management interface IP"?
- what IP are you trying to set it to?
- what hypervisor are you trying to install it on? (refer to the release notes for supported hypervisors and versions)  Any other hypervisor is not supported and may not work.
- did you follow the install guide for the hypervisor?  There are specific settings required for vWLC to work.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Hi Rich, replying below,
- is that the exact error that you're seeing "Error in setting management interface IP"? Yes, on all cWLC versions I have tried, I downloaded multiple ones from cisco and getting the same result.
- what IP are you trying to set it to? Private IP out of 192.168.1/24 The service port 1.1.1.1
- what hypervisor are you trying to install it on? Installing in in eve-ng that is running on Ubuntu bare matel server.
- did you follow the install guide for the hypervisor?  I did follow the steps from eve-ng website.
Not supported by Cisco.  If you try to run it on an unsupported hypervisor then you're on your own I'm afraid.
Supported hypervisors:
Cisco Virtual Wireless Controller (vWLC) on the following platforms:
  • VMware vSphere Hypervisor (ESXi) Version 5.x and 6.x
  • Hyper-V on Microsoft Server 2012 and later versions (support introduced in Release 8.4)
  • Kernel-based virtual machine (KVM) (support introduced in Release 8.1).
It eventually worked after assigning a different subnet to the management port. Thank you.
Maybe you had a duplicate IP allocation?
