WAP321 replacement
franky.lemaire
Community Member
Hello, Which AP can I replace the Cisco WAP321 with?
balaji.bandi
Look at other range depends on requiremetn ( at this stage there is exact replacement i see )
https://www.cisco.com/c/en/us/products/wireless/access-points/index.html#~products
BB
Haydn Andrews
It really depends on your requirements.
The end of life announcement for the WAP321 didn't specifically call out a model
Given it was targeted at small business there basically two options (unless you want to also buy a controller to manage the access point):
  • Meraki Cloud Managed (easy to setup and all the backup hard part of config is done in the cloud) - Tip you may be eligible for a free one with 1 year of licensing by watching a webinar they run this promotion regularly - https://meraki.cisco.com/en-au/freeap/
    • You can then extend the licensing out after that year if your happy.
  • Cisco Catalyst 9100 AP - running the Embedded Wireless Controller. Will require more skill to setup as not as simple as just defining the SSIDs and VLANs.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
