12-02-2021 02:16 PM
Hi Anyone can explain Cisco Network Admission Control (NAC)? its function? The below is statement of Cisco. Which means that ISE has two functions: One is ACS, and another is NAC. but what NAC does exactly? I know ACS in ISE, but which function belongs to NAC? Thank you
The Cisco Identity Services Engine (ISE) is a next-generation, context-based access control solution that provides the functions of Cisco Secure Access Control System (ACS) and Cisco Network Admission Control (NAC) in one integrated platform
Solved! Go to Solution.
12-02-2021 02:20 PM
cisco has good explanation here :
https://www.cisco.com/c/en_uk/products/security/what-is-network-access-control-nac.html
12-02-2021 02:20 PM
