02-08-2011 04:34 AM - edited 07-03-2021 07:47 PM
Hello everybody,
I have a little question regarding the WAP4410N access point.
Is it possible to mount this access point at a wall or a ceiling?
Are there any little "holes" at the back of the access point for mounting?
Or is there a "mounting-bracket" for this access point?
I've already read the data sheets and documentation for this ap, but found nothing.
Many thanks in advance.
regards,
Kevin
Solved! Go to Solution.
02-08-2011 10:45 AM
Hi Walter,
Yes ...it can be wall mounted
Cheers!
Rob
02-08-2011 10:45 AM
Hi Walter,
Cheers!
Rob
02-09-2011 01:54 AM
Many thanks for that answer!!!
