WAP521 auto reboot
Daniel Jensen
Hi.
Does any one know if it is possible to make a schedule reboot of a WAP521. I would like to reboot my AP every night at 3AM.
Can it be done from a script or something?
Scott Fella
Anything can be done with scripting as long as the script can access the device to send the appropriate reboot command. The issues is how do you go about and create that script:)  I'm no developer, so I can tell you "here is a script that can do this".  You would need to build this script so it works for you.
-Scott
-Scott
