Warehouse wifi external antennas to use 9120AXE AP
jpleppanen
Any experiences or recommendations.
Have a warehouse under design with following dimensions
corridors are ~330ft long
shelf's are 36ft high
truck are lifting pallets so space should be free up to 39 ft which is lowest height to antenna installation.
So, because of the installation height normal APs with internal antennas are out of scope and AP with external omni antenna are not option.  I've simulated with wireless designing software combination
9120AXE +AIR-ANT2566P4W-R
In simulation antenna is 'face' down and it give's a promising result (narrow signal to the corridor and no overlapping signal heard on corridors beside.)
Q: Has You experience of this kind environment/solution and/or recommendations or possible alternative solution You have used?
Br
Juha-Pekka
Leo Laohoo
Recommendation:  Get a wireless site survey done right.
Cisco Catalyst 9124 Series Access Points
