WCS/AP interface down messages
kwanm63my
Level 2
Level 2
I just turned up my WCS so it can send me some alert email messages. I now constantly see some of my remote APs ( running in HREAP mode) having the following up/down messages. The down message are usually immediately followed by a up message in less than a minute.I never lost any network connectivity to the APs during these times and have not received complaints from any users ( at least no yet anyway ) What may be causing these messages and could they be a concern ? regards
AP 'ALAP2', interface '802.11a' is down on Controller '10.101.6.12'. (3 times)
AP 'ALAP2' associated with Controller '10.101.6.12' on Port number '29'.
AP 'ALAP2', interface '802.11a' is up on Controller '10.101.6.12'. (4 times)
AP 'ALAP2', interface '802.11b/g' is up on Controller '10.101.6.12'. (4 times)
E-mail will be suppressed up to 30 minutes for these changes.
9 Replies 9
dmuralis
Community Member
Couple of things.
-When you get these notifications check the traplogs on your controller. Usually has more information and you can look for Heartbeat timeout/Lost heartbeat messages, where if the keepalives between the AP and the controller were missed for some reason, the AP would dissociate. You can also check the LWAPP uptime on the controller itself to verify if these messages are true.
If you just get Interface flap messages:
You will also see Interface flap messages when channel changes occur. Again on the traplogs you will see corresponding messages about channel change for that AP.
Interface flaps also seen sometimes when you have RLDP enabled.
Where do one look for the traplogs on the controller ? The only log file that I can find was under the management tab and for logs only 'message logs'. I don't believe RLDP is enabled.
I actually take that back and monitor the traplog the moment I saw the email.. but not sure if it's shedding any light for me..
The AP base radio mac address is 0:23:04:30:bc:d0 so I've included that section here.
Wed Nov 4 10:13:43 2009 AP's Interface:1(802.11a) Operation State Up: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
8 Wed Nov 4 10:13:43 2009 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
9 Wed Nov 4 10:13:43 2009 AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
10 Wed Nov 4 10:13:43 2009 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
11 Wed Nov 4 10:13:43 2009 AP's Interface:1(802.11a) Operation State Up: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
12 Wed Nov 4 10:13:43 2009 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
13 Wed Nov 4 10:13:43 2009 AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
etc
etc
some misc. Rogue AP messages and coverage hole here but the base mac is not the same so it probably came from another APs so I have not included..
etc
etc
15 Wed Nov 4 10:13:43 2009 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
16 Wed Nov 4 10:13:43 2009 AP's Interface:1(802.11a) Operation State Up: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
17 Wed Nov 4 10:13:43 2009 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
18 Wed Nov 4 10:13:43 2009 AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
19 Wed Nov 4 10:13:43 2009 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
20 Wed Nov 4 10:13:42 2009 AP's Interface:1(802.11a) Operation State Up: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
21 Wed Nov 4 10:13:41 2009 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
22 Wed Nov 4 10:13:41 2009 AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:00:23:04:30:bc:d0 Cause=Admin Configured
On your controller itself if you look at "show traplog" from cli or from GUI- Management tab-> SNMP-> Trap logs, you will most likely see messages like :
Channel change on radio .... etc.
Are you seeing anything like that at all in the traps?
Once you determine you see no Channel change messages at all for the AP in question in the traps, check your Rogue location Detection Protocol and see if it is enabled.
I don't see any channel change message.
On my Rogue policies, it's disabled.
Under the "auto contain" options..
all 4 options are unchecked...
In fact, I believe these are all the defaults on the Rogue Policies page.
Is the LWAPP uptime corresponding to these flaps? Or does that remain normal?
The AP uptime never show that it dropped..
I'm not sure where to check the LWAPP uptime unless it's this. I do see a time statistics area under the general tab
and I do see a controller associated time and a controller association latency.
In there, I see that the associated time does seem to correspond to the last flap
Controller Associated Time 0 d, 01 h 03 m 57 s
Controller Association Latency 0 d, 00 h 01 m 23 s
I just had a another flap ( seen via email notification from the WCS ) and this time the 'time statistics' area is not really corresponding exactly..
