WCS not graphing CleanAir Interferers
jlhainy
Level 7
Level 7
I have WCS managing 4 controllers.  1 of which has clean air enabled.  WCS gives air quality reports just fine, but it gives me no information on the Device Interferers or the Interferer count.  I can go to the controller, go to monitor>cleanair and look at the APs that find interferers and then graph the data to show bluetooth, microwaves, continuous transmitters etc, but why is this info not seen in WCS?
From WCS config guide :
te
The  information in the worst interferer and interferer count charts is  collected from Mobility Services Engines (MSE). If MSEs are not  available, this chart will not show any results."
http://www.cisco.com/en/US/docs/wireless/wcs/7.0MR1/configuration/guide/wst.html#wp1168776
6 Replies 6
Nicolas Darchis
You need a PLUS license on WCS and you also need a synchronized MSE for WCS to display the interferers because they will be merged by the MSE.
I have the Plus location license, what I don't have is the MSE.  So you are saying I need to have the MSE for it to graph the interferers data.  I am not trying to to see them on the map, but on the clean air tab, there are various graphs.  I figured that the interferes graph would just show a grapch of the types of interferers like Microwaves and bluetooth devices, like the WLC does.  Is this not the case?
te
Awesome, that is what I was looking for.
Thanks.
Thanks Nicolas for information on mobility service engine (MSE).
Vinay Sharma
COmmunity Manager - Wireless
Thanks & Regards
one needs for the Air Quality graph in the WCS also a Mobility Services Engine appliance?
These values ​​are in my WCS 7.0.172.0 PLUS will not also be shown.
Thanks an regards.
