09-11-2010 09:08 AM - edited 07-03-2021 07:10 PM
Our Cisco WCS4402 suddenly stopped authenticating 802.1x clients. Public WLAN works fine. Software version 4-1-185. Sytem has been rebooted several times. Any suggestions appreciated.
09-11-2010 09:19 PM
Hi Dave No recent changes? I would first check the wlc log and post what it reports on one of the failing clients On the acs side.. Look under the failure log and see if you see an error MSG for this client post what you see
09-12-2010 01:45 PM
Hmmm nothing changed?
As your code is quite old I would check the cert validity on the RADIUS side,
Definitely check the logs if you are using Windows or ACS the logs give pretty straightforward error messages that will help.
