05-21-2004 02:23 AM - edited 07-04-2021 09:39 AM
We have successfully configured an AP as WDS and registered infrastructue Access Points. The WLSE has also successfully been authenticated by the WDS AP. My problem is when I move the WLSE onto a different subnet it looses the connection. I understand the WLCCP uses multicast, is this also true for conversation between the WDS and WLSE? Do I need to enable Multicasting on my router?
05-21-2004 09:32 AM
When you say that you move WLSE to a different subnet, do you mean that you're changing it's ip address to a different one than previously configured?
05-24-2004 12:13 AM
I actually moved the Access Points on to another subnet.
09-14-2004 04:48 AM
Do you use an external radius server or the local radius server to configure your ap to be an WDS AP.
Can i get a copy of your config i am struggling to get AP authenticate with local radius but it is not working to well?
Regards Bjorn Sundin.
