Web authentication on 891FW
markomit81
Frequent Visitor
Frequent Visitor
Can I use my 891FW router to authenticate wireless users on HTML page asking LDAP or TACACS for credentials, giving them access? When connecting to open SSID, web page in php that I will create (along with reject.php when they enter wrong password) should open, asking them to enter credentials.
If credentials ok, google homepage should open.
Thanks in advance.
You need to look at the guide to see if webauth is supported or not. If not, then you will have to look at a 3rd party tool/software that can do this for you.
-Scott
balaji.bandi
Personally i do not believe you able to achieve this with by itself with 891 model.
you need to configure to redirect to process this request out of the box, example guide:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_aaa/configuration/15-mt/sec-usr-aaa-15-mt-book/sec-cwa-url-redirect.html
BB
in my organisation we don’t have ISE but ACS Tacacs server for
authentication. Can this be implemented with ACS?
-Scott
