WGB
fcoppotelli
Community Member
i need to connect two building using one AIR-AP1230 and one AIR-BR1310G,the problem is that the AP have some SSID configured (voice,data,voice wirlesse,data wireless) and authentication LEAP.The bridge must be a workgroup bridge to connect the wired/wireless user to the domain.I tried to configure the AP as root and the second as WGB but the Fastethernet is disabled.
Can someone post the settings to do it, or explain how to do it?
smalkeric
Level 11
Level 11
To connect the building using a AP and a Bridge, you have to configure the AP as a Root Bridge and the Bridge to be a non-root. In any point to point wireless link you need to have a root bridge and a non-root bridge. Since you have the AP on one side you have to configure the AP as a bridge (as a root bridge). For connecting the wired clients to the wireless domain, you have to use a WGB or a AP can be configured as a WGB.
