877w connectivity & config problem
kradjesh13
Level 5
Level 5
This is the first time i am configuring a wireless router. I am facing difficulties since the client machines i not connecting with the wireless router. I tried out all, but i dont where i am going wrong. So i am attaching the piece of my config and need help from you guys.
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 300
encryption vlan 1 mode ciphers tkip
ssid test
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii password
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description xxxx
no ip address
bridge-group 1
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip inspect DEFAULT100 out
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname [email protected]
ppp chap password 7 xxxxxxxxxxxxxxxxxxx
ppp pap sent-username [email protected] password 7 xxxxxxxxxxxxxxx
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip access-group 100 in
ip nat inside
ip tcp adjust-mss 1452
Thanks in advance.
Rajesh
pradeepde
Level 11
Level 11
Try this document.This document explains how to configure a Cisco 870 Series Integrated Services Router (ISR) for Wireless LAN connectivity with WEP encryption and LEAP authentication.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080608364.shtml
george
Level 2
Level 2
Hi Rajesh,
I am troubleshooting the same problem, did you manage to get this work?
./G
