Showing results forĀ
Search instead forĀ
Did you mean:Ā
What am I doing wrong - SSL Cert for WLC Generation
roger perkin
Level 2
Level 2
I am following this to the letter
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html
I have generated a CSR and got back a signed cert - however when I try to generate the final cert I get an error
When running this command
openssl>pkcs12 -export -in All-certs.pem -inkey mykey.pem
-out All-certs.p12 -clcerts -passin pass:check123
-passout pass:check123
I get an error
no certificate matches private key
pkcs12 error
Anyone know what I could be doing wrong?
Roger
George Stefanick
What version of OPENSSL did you use? I think you need to be 99 or lower.
I am using 0.9.8
