What does NAC State do?
I am trying to figure out what the NAC State option under Advanced tab in a WLAN does if I sett it to ISE.
What extra information is sent to the ISE?
I have a usecase to do both dot1x and MAB on the same SSID. To be able to do that I have to set NAC state to None, at the moment it is set to ISE NAC. I do have a ISE-server for authentication.
What I want to know is what I loose if I change it from ISE NAC to None.
Philip
Hi Philip,
WLC will not support both MAB and 802.1x on a same SSID.
These two links explain the Radius/ISE NAC Radius NAC and Wireless LAN Controller RADIUS NAC and CoA Overview
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
patoberli
As far as I know, dot1x with username/password or certificate and also MAB on the same SSID is not possible.
No idea what that option does though.
Hi Philip,
