What is the current consumption of C9115AXI-K?
CCC3
1. What is the current purpose (A) of C9115AXI-K?
2. Is there a difference between booting the AP and using it normally (assuming resource usage at 50%)?
2-1. If there is a difference, how much is A for each?
3. Can the difference in current consumption between one unit and multiple units (140 units) be multiplied by 140?
If you know, please reply.
thank you
Rich R
As per https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/datasheet-c78-741988.html#Productspecifications the specified power requirement is 20.4W
In reality this is what a 9115AXI running 17.9.4 software is consuming:
From CDP:
Power drawn: 18.900 Watts
Power request levels are:18900 15400 0 0 0
From switch inline power management:
Power drawn from the source: 18.9
Power available to the device: 18.9
Actual consumption
Measured at the port: 6.2
Maximum Power drawn by the device since powered on: 8.9
For the purposes of power budget you should assume 20.4W x 140.
Nearly the same as mine, it's using 7W on the switch port. But this is with very low utilisation.
