what's the algorithm for interface groups assingments on wlc 5508?
victorcossio
Frequent Visitor
Frequent Visitor
I'm trying to find a trustworthy source about the assignment algorithm of wireless traffic when many wireless clients send traffic to WLAN associated with an interface group, let's say with 4 VLANs.
the documentation below doesn't say anything about which algorithm is used. is round-robin? hashing of some form(with MAC/IP)? what else?
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/ports_and_interfaces.html#interface-groups
I hope you can clarify this.
greetings.
See https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-6/b_Cisco_Wireless_LAN_Controller_Configuration_Best_Practices.html#concept_4CBC85029ED6485984F92D8D460E2015
It uses hash by default but can switch to round robin as noted.
Also note the feature was previously called VLAN Select.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
5 Replies 5
jagan.chowdam
Refer "Interface Group" section from the link. It is round robin fasion.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/ports_and_interfaces.html
  • Upon a client's connection to a WLAN managed by a controller, a hash index is computed utilizing the client's MAC address and the interface group's quantity of interfaces.
  • This index dictates the assignment of an interface to the client.
  • Upon subsequent connections to the controller, the hashing algorithm consistently yields the same index for the client, ensuring assignment to the same interface.
  • In cases where the designated interface is marked as "dirty," a random index is generated to facilitate interface assignment.
  • Should the designated interface remain in a "dirty" state, a fallback to a round-robin approach is enacted.
Jagan Chowdam
/**Pls rate useful responses**/
Jagan
I am bit confused by your answer. you claim that is round robin but the description below clearly states it as hashing with MAC.
so which one is the verdict?
also. the link you are referring to doesn't contain the information you provide. with a quick Ctrl+F search for you will see this. where did you get the information in your answer?
thanks in advance.
eglinsky2012
Regarding hashing the MAC address to preserve VLAN assignment, does this work with multiple WLCs (including a mix of 9800/8540) in a mobility group? For example, if a client on WLC 1 later joins WLC 2 (whether it's another 8540 or a 9800), will WLC 2 assign the client the same VLAN as WLC 1 did?
At a guess I would say 2 8540's with identical configuration, yes.
I'd be very surprised if you got the exact same result with 8540/9800 - if you want to do it then test thoroughly.
