What should be ideal AP connected swich port configuration
subodh goyal
What should be ideal AP connected swich port configuration? We have configured below config in our environment but sometimes facing issues due to same. Please confirm if there is any issue with below config.
Access point Interfaces
Local model Access points
interface GigabitEthernet <interface id>
description wireless_ap
spanning-tree portfast
switchport
switchport mode access
switchport access vlan 90
logging event link-status
logging event power-inline-status
service-policy output AutoQos-4.0-Output-Policy
no shutdown
Flex connect Access points (with Local Switching)
description wireless access point
switchport
switchport trunk native vlan 90
switchport trunk allowed vlan 90,40, 50-59,78
switchport mode trunk
spanning-tree portfast trunk
service-policy input AutoQos-4.0-CiscoPhone-Input-Policy
no shutdown
balaji.bandi
That should be ok - personally i remove auto QOS and test it
what kind of problem ?
Also you have some other VLAN other than 40, in the trunk what are that VLAN for ?
make sure layer 2 spanning  correctly (if you have STP root some where ?)
BB
JPavonM
Agree to @balaji.bandi by removing AutoQoS line if you don't have end-2-end QoS configured from endpoint to the WAN router, and giving us additional information about the issues you are facing.
Those configurations are the basic ones for APs in local and Flexconnect mode so no problem on that.
I will recommend you to review the IOS code the switch is running (seems to be pretty old switch due to the fact tha you need to set the encapsulation piece) and the trunk port oversubscription. Additionally, as you are not mentioning the AP model you are using, and supposing you are using a mid/high-end enterprise model, check whether your switch do support PoE+, otherwise you can notice weird behaviours like disconnections, or low performance due to AP disabling some radios/streams.
