Showing results forĀ
Search instead forĀ
Did you mean:Ā
Catalyst 9124 Stuck on EWC-AP in Recovery Mode
H&M
Hello All,
I was trying to convert my cisco c9124axi to ewc, I  use the commands
ap-type ewc-ap tftp://x.x.x.x/ap1g6a tftp://x..x.x/C9800-AP-iosxe-wlc.bin
After reboot I got the error
EWC-AP in Recovery Mode......
Please use 'archive download-sw' to upgrade AP and Controller image.
Please use 'show flexconnect ewc-ap launch-log' to check EWC-AP launch log.
This prompt keeps coming and doesn“t let me do anything,
I don“t know how to solve this issue can someone guide me on any solution?
Thanks!
6 Replies 6
balaji.bandi
i would suggest try some OLD version and check : (Hope you Trying IOS XE 17.13.X ?
Try 17.9.4a and let us know.
check below thread also help you :
https://community.cisco.com/t5/wireless/can-c9124axi-row-act-as-ewc/td-p/4764005
recovery :
https://0x2142.com/how-to-convert-catalyst-9100-ap-to-embedded-wlc/
BB
marce1000
                - FYI :  https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvy82493
           - What's the content of the AP launch log (according to instructions mentioned)
 M.
H&M
Hello all thaks for your response but for some reason I can't exit the prompt
I don't know if someone knows how to go back to the # to get the AP launch  log or to recover the controller image.
 - FYI : https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9120axi-access-point/217537-repairing-c9120-c9115-access-points-from.html#anc4
 M.
Hello marce1000,
Searching for the Access Point Manufacture Image I donĀ“t find any image for C9124AXI access point.HM_0-1705526504103.png
Have you tried any other versions? I've been wrestling with the same problem on 17.11.1 and got it to work by installing 17.10.1 via the archive download-sw command. See link below.
https://software.cisco.com/download/home/286326654/type/286323077/release/17.10.1
