06-05-2019 11:45 AM - edited 07-05-2021 10:31 AM
Hi we lose an AP connection with WLC among several hundred APs. Which is fast way we can find which one lose connection? Can we find it via WLC? Thank you
Solved! Go to Solution.
06-05-2019 12:37 PM
WLC can not generate any report like that as such.
Option 1
Using Prime you can generate alerts
Opetion 2
Configure WLC with syslog server
Capture the Logs and send alerts email to admin group.
i am not sure wth solarwinds snmp you can get that information, never tried myself.
06-05-2019 11:57 AM
how are you managing the WLC ? if you using Prime infra, you can set alert as soon you loose conenction with AP.
06-05-2019 12:09 PM
We are using Solarwind. our solarwind sometimes has problem. I guess we cannot know the lost AP via WLC
06-05-2019 12:37 PM
Option 1
Opetion 2
