Why can I set the interface for a Wlan in 2 separate places on WLC
jon.baxter1
On a 5520 WLC
when i create a wlan, i have to assign it to an interface.
when i create an AP group, then add a wlan to it, I have the ability to assign an interface here was well.  the note on it reads below, but doesn't really apply since i am no using FlexConnect for anything.
So why can I do this?  What happens if they are set to different interfaces (not really sure I want to test)?  I cannot find any documentation on this.
Interface assign under "AP Group" will take precedence. In that way you can override WLAN map interface to different interfaces based on AP Group.
Rasika
*** Pls rate all useful responses ***
Rasika
