Why certificate info has gone at wlc
interfacedy
Hello, We need configure certificate for vWLC9800 sometimes. The commands are like below:
WLC(config)#ap dot11 5ghz shutdown
WLC(config)#ap dot11 24ghz shutdown
WLC(config)#wireless management interface gig 1
WLC(config)#ap country US
WLC#wireless config vwlc-ssc key-size 2048 signature-algo sha256 password 0 abc
WLC#show wireless management trustpoint
Trustpoint Name : WLC_WLC_TP
Certificate Info : Not Available
Private key Info : Not Available
FIPS suitability : Not Applicable
After running these commands, the original info of certificate has gone. it become "Not Available"(original is Available). Did I miss some step or some step wrong? Anyone can explain commands briefly? Thank you
5 Replies 5
jagan.chowdam
Verify your wireless management interface.
By default, the 9800-CL comes with three network interfaces:
●     GigabitEthernet1 -> Device management interface: Map it to the out-of-band management network. This is the equivalent of the service port.
●     GigabitEthernet2 -> Wireless management interface: Map it to your network to reach APs and services. Usually this interface is a trunk to carry multiple VLANs.
●     GigabitEthernet3 -> High Availability interface: Map it to a separate network for peer-to-peer communication for SSO.
CJ
""Please rate all useful responses""
Scott Fella
You should see some info, did you reboot the controller?
-Scott
Its very strange. I often see the two below info, but dont know why it happen. Do you have any idea on that?  Thanks
When I see what you have posted, its usually an issue with the trustpoint.  I basically delete it and create a new one.  The issue for me was on earlier code version, not the later ones.
-Scott
saravlak
I think this could be the issue. Try with vlan instead of gig int for wireless management and then do the cert creation.
C9800(config)#wireless management interface vlan X
